1 - 1 of 1 Posts
Recently while browsing the web I found this post which I figured I would compile what was on the thread as well as provide and updated the list of common problems and problems that can occur with the RSX.
That being said I hope this helps you guys find fixes and solve issue with your cars. Also if I miss anything please contact me and I will update this Thread, Thanks!!
I would just like to throw out I have owned an RSX for around 7 years now. I have encounter some problems but most of these I haven't. I will try to provide my best answer and solutions. I am finding the problems and hopeful answers from research online!! Please do not use this as a go to for your car problems I am just trying to provide insightful help!!
Know Common Problems
Problem
Grinding feeling going into Second Gear(Second Gear Grind)
Solution
Many people are saying you can change the Tranny Fluid for a synchromesh and Get Results. others say to put a heavy shift knob on.
Here is a link on changing the fluid if you are a do it yourself person
http://forums.clubrsx.com/showthread.php?t=378063
Problem
Dash Rattle
I have had this problem myself. Here is a fix!! Also check your glove box sometimes the lock mech gets a little loose and will rattle on you. I personally took my car to have the rattle looked at and fixed.
Solution
http://www.acuraworld.com/forums/f27/easy-dash-rattle-fix-93909/
or
http://forums.clubrsx.com/showthread.php?t=458329&highlight=dash+rattle+fix
Problem
Leaking Taillight Gasket
I have not had this problem but my friend had it in his car we followed this post
Solution
http://forums.clubrsx.com/showthread.php?t=549910
Problem
Failing door actuators and Failing trunk actuator
Solution
Simple buy new and replace.
Haven't had the problem personally
Known Problems (not sure if they are common)
Problem
Rear Trunk Struts Failing
Solution
No need to worry its a common problem with hatchbacks! They just wear out just buy new easy to replace yourself.
Problem
Rear Calipers Freezing
I had this problem myself. I got out of my RSX after work to find my Rotor Bright Orange had to take a hammer to my stock rims to get it off. Thank GOD They were on!!
Solution
Buy a New caliper and put it on yourself if you know how.
http://diyacurarsx.blogspot.com/2014/04/how-to-replace-rear-rotors-and-brake.html
Problem
TPS Sensor and or Knock Sensor Failing
Currently fighting this problem right now. Im personally just buying new and having them installed. Here is a DIY if you feel you can do it.
Solution
Buy new and install.
http://forums.clubrsx.com/showthread.php?t=767559
or
https://www.youtube.com/watch?v=YBfLcN6F184
1 - 1 of 1 Posts
