1 - 20 of 130 Posts
This is how the EVAP system looks like when it's on the car. I'm planning to remove the entire system.
This is how it looks like after the EVAP system is removed. Is it alright to just cap off the ports circled in red? In K-Pro, i have the emissions checking disabled, so that means if i remove the system, i won't throw a CEL right? (there are 3 plugs that connect to the EVAP system under the car)
Mostly stock, Mostly
Why do you want to remove it?
Discussion Starter #4
i already have the evap canister purge valve deleted from the throttle body and the entire hardline that runs back to the canister, out. Just wanted to see if i could remove the whole contraption.
I'm pretty sure you still need to vent the gas tank as high as possible.
so should i run 2 hoses from the red circled areas to vent near the rear bumper?
Discussion Starter #6
Alright, so the assembly circled in blue leave intact? For the port that has the orange arrow pointed towards it, do i plug that?
do you have your canister removed as well btw?
Discussion Starter #7
Just took a quick pic outside. Put the 2 lines back that run to the gas door. The areas i have circled in red is the ones i needed to have plug correct?
Discussion Starter #10
I just took a look at the EVAP diagrams on ALLDATA and the way we have it setup won't work i think. The way we have it setup wont vent anywhere. It looks like it will recirculate around the fill pipe only.
here is the RSX diagram
here is one off the 98 Integra
The only way to vent the gas tank is run a line on the EVAP valve on the gas tank to the back of the car since both the RSX and Integra have it but only the RSX has a fuel vapor control valve. Then plug the fuel vapor control valve. What do you think?
U mad bro?
interesting... which one in your pics of your tank the evap valve on the gas tank?
Discussion Starter #12
the evap valve is circled in red. the port circled in orange (fuel vapor control valve) needs to be plugged. when i blow air into the fill pipe & have the fuel vapor control valve plugged, air is able to come out from the evap valve. when i blow thru the evap line, air is able to come out from the fill pipe. that means if the gas tank needs to vent, it will vent, and if needs to breathe, it will breathe.
gingers have no souls
i read that part but whats the benefit of the evap delete on the throttle body?
U mad bro?
So plug the orange and run a tube from the red... that would eliminate the white piece as well right? what about the lines going up to the fill area from the white piece?
Discussion Starter #19 (Edited)
yes, plug the orange area, run a tube from the red area which inturn would eliminate the vapor control valve (the white piece). the 2 hardlines that go to the fill area (the 2 lines the vapor control valve connects to) is to collect vapors when you pump gas but the pumps already have vapor recovery. i was gonna cut the 2 hardlines as close as i can to the fill area and crimp them close.
Extra shit is extra weight. Not to mention more stuff that can get in the way or complicate an already busy engine bay.
pretty much this and im doing a wire tuck as well so all the harness to do with the evap was de-pinned at the ecu.
U mad bro?
I just talked with a friend of mine about this.
he said to leave it like this:
with the red circles plugged. he said the 2 lines are venting when you fill up but other than that you don't want any other air leaks.
1 - 20 of 130 Posts
