Status
Not open for further replies.
1 - 20 of 2125 Posts
Running from the Blerch
I spoke to the Comptech rep yesterday at SEMA in Atlantic City here in NJ and he said that they will be producing a supercharger for the Base RSX
me and another member, RSX-Bob, talked to him for like half an hour about the S supercharger and the base supercharger
He said that the manifold has been adapted from the S to fit the base RSX and the TSX
he also said that the base will run a black box piggy back ECU program for the management of the base system - he said it will change the VTEC engagement point and i think he said something about changing the cam phasing but im not too sure (really cant remember that and the two other things he said the program will be doing)
he said expect the base kit to be around the same price as the Stage I kit for the S and it should be out in about 6 months - they are going to release the TSX kit first, then the base RSX kit - and a type S stage II kit should be out soon too
he said the major detail that needs to be finalized on the base kit is the piggy back system - they have 4 prototypes made so far and are working on finalizing the design
he also noted a few things about the SC kit that make it very unique:
the injectors are Honda injectors that are re-machined for higher fuel output - no messing with RC injectors
every bolt on the system is a honda bolt and will be the same size as the stock bolts - no needing to change sockets when removing the stock IM and putting on the SC
the kit can be purchased at the dealer and installed by the dealer - you will experience some warranty issues from Acura over it but if the kit breaks for any reason, Comptech will pay the dealer to pull the supercharger and fix it
he also said the kit is moderately easy to install by yourself - just need to read up on the directions on their site and take your time
oh one more thing - he said that the supercharger will be available for the base 5 speed and base auto RSX
time to start saving :D
Discussion Starter #4
i knew you two would like the news
i had to post it and share it with the rest of the members
hooray for Comptech!!! :thumbsup:
Discussion Starter #8
sithlord said:
OMG!! OMG!! OMG!! FOR THE AUTO!! THE AUTO!!!!! :thumbsup:
no estimated date huh.
no - he said about six months for it
they just need to iron out the details with the piggy back system and start coming up with the online directions for the TSX and base kit
Discussion Starter #11
Shifu said:
5speed! 5speed! everybody is screaming auto...i thought i should scream 5speed! comptech says 6 months anything from JR?
i think the news is awesome for both the 5 speed and the auto
i personally have an auto and plan to start saving for it now but i know there are many other 5 speeds who will want this kit :thumbsup:
last thing i heard from JR was more delays on their kit :dontknow:
Discussion Starter #13
kurdtkobain87 said:
hey nirvanaandtool (by the way nirvana is the shit) are you 100 percent positive about the auto???
thanks - Nirvana is amazing :thumbsup:
yea
the Comptech rep at SEMA specifically said that the kit would be compatible for both the 5 speed and the auto
im pretty sure its the same deal with the TSX too because the TSX kit uses a similar piggy back system
base this base that, what about the Stage 2 kit for the S?
Higher PSI pulley, new injectors, different K100/KPro setting, and an aftercooler? (That's my guess on what it should have.)
Discussion Starter #15
well we all have bases hence being why we care more about the base ....
im not too sure about the stage 2 kit details
i know they are working on an aftercooler - they are playing around with the fin setup to get the right amount of temperature drop and pressure drop over the aftercooler
i know you can get either a reflash or KPro and they are going to use a higher psi pulley on it
not sure on the injector details for it
hope that helps some :thumbsup:
omg! im so excited! cant wait! yeeepeeeee
does comptech have their own IMG to install with the supercharger? if so, i wont be able to use my hondata IMG anymore and will have to use theres?
edit: yay!!!!!!!1
If ur not 1st ur last
edit: yay!!!!!!!1
Yes they have their own IMG.
Discussion Starter #20
ya
the rep said they found some polymer that works very well as an IMG in cooling the s/c IM - he said it performs better than the plastic hondata and nextgear IMGs
Status
