1 - 4 of 4 Posts
So, I have a 2005 rsx base model. The cruise WORKED before I had some issues come up. The left front wheel sensor was broken before hand, so the abs light was already on.it worked even though the sensor is broken.I then got a check engine light for a p0325 (knock sensor code) and cruise stopped working. Since then I have fixed the p0325 and cruise DOES NOT work now. The green light for the cruise switch on the dash lights up. Anyone know what may be wrong?
About to replace that knock sensor as well. Did you go in from underneath?
[/QUOTE
No. I just pulled the intake off. It's about 40 minutes of work. Not bad. And then it's just right there. Pull the air box and throttle. Make sure to plug the intake vacuum line backer up, I forgot and it set a p1077. So I had to do it again
1 - 4 of 4 Posts
