1 - 20 of 25 Posts
My butterfly bit me
cybernation?
My butterfly bit me
no is it a porn site?
My butterfly bit me
::sarcasm:: theres a turbo kit out? ::sarcasm::
Master of Auto Talk
am i actually the first to do a ...
IBTL
SilverRSXJezus said:
wait..so like..if you write "turbo" on a sticker.and put it on your car...does it go faster?
Well if you want to get technical, then the answer is yes but it also depends upon the type of surface used in decal. The surface of the adhesion needs to be constructed of light filament fibronectin carbon entoproct inlays, which when heated at optimum surface temperatures release a high electromagnetic spectrum. The spectrum then disperses endergonic energy catalysts. hence, increasing the an optimum expenditure of energy.
Out on bail
yea but the endergonic reaction catalysts always eat the protein in the catalytic converters C-section of the by-pass valvular gaskets in the aorta. this is why it is a VERY good idea to run test pipes with this type of turbo sticker boost setup.
ummm no thats wrong... the endergonic energy catalysts actually reduces the optimum expenditure.... you need to construct the adhesion with the light filament then balance the electromagnetic release or the catalysts will react in a negative force field...
once that is accomplished then you can say "beam me up, scotty" and you'll instantly hear a pssssssshhhhhhhhhhh sound coming from the sticker's bov....
lmfao, hahahahahahaha!
1 - 20 of 25 Posts
