Okay one last question. I just wanna be clear about which is feed and which is return. From what I've been told, the oem line gets reversed and fuel "returns" to the pump through there. Is that the case in this setup? Or is the return going to be that extra line I install?
This setup is going to replace the oem hose w/ greeen clips right? The one that connects to the rail, and that one thats tucked back on the firewall (also has a light green clip).
After the return and feed is confirmed I'll be able to handle the rest. I know the pressure is enormous, would I simply slide the hose over that small tube and tighten a hose clamp over it?
