1 - 5 of 5 Posts
RSX-S Owner
Been helping my friend out with his 91 DA, he's been having issue with his turn signals. When you turn on the hazards every things works properly, just the front bumper lights blink. When you turn on the right turn signal that also works properly, the corner and bumper lights alternate. When you turn on the left turn signal, it works properly and alternates the corner and bumper lights, but the right corner light also blinks. Any thoughts?
no time to drive the RSX
anything been modified in the lighting? Any grounds corroded? Do you have a wiring diagram?
x2, also check if all the bulbs are working condition.
Premium Member
If you have access to a wiring diagram it would help a lot. My 88 CRX was a nightmare. The previous owner had fogs wired in, the bumper turn signals were hacked out, the upper corner light turn signals didn't work right, and the fender lights also did not work correctly. I pulled up a few diagrams for mitchell on demand and all data. From there I removed the front bumper and went to town on properly wiring everything.
1 - 5 of 5 Posts
