1 - 14 of 14 Posts
Hey all,
I have a set of Brembos from a DC5 Type R. I am in the process of rebuilding them and need to order new seals, boots, etc. I need to know what size diameter to get the rebuild kit, and I can't take the piston out at the moment to measure it.
Someone here once said they were 32/36mm, but I found these two sites with the OEM Brembo seal kits from Honda and they both say it's 36/40mm. Here are the two sites:
http://y.2-d.jp/blog/cowboy/2012/09/28/
http://happoya.jp/?pid=33552081
I know the Honda part number for the Brembo seal kit is 01463-S6M-J51.
Does anyone know definitively what size the pistons are on these Brembos?
Also, probably a dumb question, but assuming I find the piston size, should the seal kit be for the same size or should they be bigger and account for some spacing?
Discussion Starter #2
Ok, so I finally had some time to disassemble the calipers and took the pistons to get measured. For anyone else interested the piston sizes on the DC5 Type R front Brembo calipers are 40mm for the larger, and 36mm for the smaller piston.
Additionally I ended up purchasing a new seal/boot kit for my Brembos from StopTech. They (seals/boots) are interchangeable with Brembos.
Hope this helps.
I am doing the same. And can not find a rebuild kit for them anywhere!!! And you said you found a kit from Stoptech? did you order them or did you call and order them? If so do you have the link or the phone number?
Discussion Starter #4
The guys at Street Lightz got them for me. Call them up, and make sure you tell them the correct sizes, listed above.
Thats what I was thinking.
I am also going to try my local Honda dealer tomorrow because I get a discount through them from my shop.
Hey bro,
the 36mm/40mm from Stoptech works well or not?
I find on ebay
http://www.ebay.com/itm/36mm-40mm-Stoptech-Brembo-Front-Brake-Caliper-Rebuild-Kits-Qty-2-/271630575812?hash=item3f3e71a8c4:g:VJsAAOSwwPtTwB~z&vxp=mtr
I need for dc5 brembo calipers. Not sure is work like Genuine honda.
Why don't you buy OEM?
http://jp-carparts.com/honda/partlist.php?maker=honda&type=INTEGRA 3D&cartype=850&fig=B&fig1=2201
https://www.amayama.com/en/search?q=01463-S6M-J51+
^$15 USD cheaper, and I have used them twice with great service.
New Old BB6
Anybody know the piston legnth? I scratched one of the 36mm pistons pulling it and need to order a replacement. ��
NvUS East Coast
Hey Guys. Bringing this thread back to see if I can get a simple answer. Is there supposed to be a flat seal that goes between the two halves of the caliper (for the hole the transfers brake fluid between halves)? I'm getting some seepage from between the two halves. I know some brembo sets do but no sure if the dc5r ones use them.
1 - 14 of 14 Posts
