1 - 11 of 11 Posts
HI2U
I just got door slapped by some girl today at school and i was wondering how much is a detail? Or should i just get some touch up paint from autozone and do it myself? Are there any comparisons?
Well, first of all did it leave a dent? If it left a dent, You`ll probably want to get some Bondo, 1000 grit sandpaper (for first sanding), you`ll also want to wet sand it, with it being clear coat base coat, and then apply the bondo, then sand it....depending on if your wanting it back to the factory quality look. You`ll also need to buy some paint, depending on the size of the chip, you might be able to use the touch up paint.
Godzilla 4 Rilla Crew #5
If theres paint missing you either have to repaint the entire panel. Detailing can hide it to only a certain extent.
1 - 11 of 11 Posts
