61 - 69 of 69 Posts
Can anyone help me by which model dakota digital box its suppose to be i have and 02 base rsx and running an 06 base rsx tranny and have the sgi-5e but cant get it to work a drawn diagram would also be great
so i got 05 type s-
On cold Start the engine wood rev- replaced 02 sensor but no luck. then transmission failed in matter of weeks- had for bout a year, 2nd owner on 130K miles.
my mechanic say to import brand new Japan Transmission-
but i can rebuilt also a 2004 type-s transmission in my garage.
anyone have experience on what route is better?
so i got 05 type s-
Depends on what you want to do
Replacing trans is probably cheaper than rebuilding one unless you do it yourself
If you rebuild the 04 you'll need to get a speed converter or the speedometer won't work
Sent from my SM-N915T using Tapatalk
i wuld need a speed converter to mount 04 on a 05?..didn't know that...thnx
instead going to purchase imported transmission from Japan, final decision.
Anyone recommend where to purchase from?
Having trouble with my dakota digital converter calibration. I have it wired up as it's stated on this thread. When I get out to calibrate, unit shuts off. Could it be wired wrong?
02 Rsx with Type S ecu
06 Si transmission
si speed sensor & plug
On 02-04 engine harness
Green/white (signal) ---connected to --- Output #4 on dakota digital box
Black (ground) --connected to -- green/black on 06 si vss plug
Yellow/black (Power) --connected to-- yellow power on 06 si vss plug
Black/white --connected to-- Signal input on dakota digital box
grounded to ecu mounting bolt
Power from 12v source on ecu plug wire #1
That's how I have it set up now. Can't seem to get this thing to calibrate, keeps shutting off.
61 - 69 of 69 Posts
