1 - 4 of 4 Posts
エアロキット&#
2004 Acura RSX Type S Milano Red
My girlfriend wants some green lugnuts on her eagle talon, and I wanted to
know if I used some duplicolor "metalcast" paint- would it hold at all?
Any other ideas on how to do it, or how much it would be to get them anodized?
How is that process done the real way?
Engineering
process is done electrochemically. a cathode is connected to the negative terminal of a voltage source, then placed in an anodizing solution (some time of acid, for example sulfuric acid). the thing being anodized is connected to the positive terminal of the voltage source, then placed into the anodizing solution as well. when the power source is turned on, the oxygen will liberate itself from the water in the solution and coat the thing being anodized. this oxide coat is then dyed the color you want
1 - 4 of 4 Posts
