DIY - Fix Broken Hood Latch Mount
53914 Views 37 Replies 30 Participants Last post by  Lucky16
7
Alright so the other day while driving I noticed my hood bouncing up and down. I pulled over and found that where my hood latch bolts onto (upper bulkhead) had completely snapped so the latch was just bouncing around. I looked around quite a few places online to find a solution to the problem, and didn't find much so I figured I would write a DIY for anyone else that has this problem since it seems to be a somewhat common problem.
Once I actually got home and went to open my hood the cable had popped out of the latch so my hood was basically locked down and I had about a 3 inch gap to get in and try and get it loose with my hands.
Parts/Tools:
- Front Bulkhead (upper) part # 04602-S6M-A01ZZ
- Bulkhead Center (optional) part #60434-S6M-A00ZZ
- A set of metric sockets/wrenches
- Pliers
- Screwdriver
I did not buy my parts from here but it is a good reference. http://parts.sonsacura.com/products/Acura/RSX/FRAME-SET--FRONT-BULKHEAD-UPPER/1452602/04602-S6M-A01ZZ.html
Notes:
If you can get your hood open already, you will save a lot of time. In my case the latch was locked on and the cable was unhooked so I had a hell of a time getting it open. I got the hood open to about a 3 inch gap and was able to get in there and work on it. I removed the three bolts on the latch itself and was able to shake it loose allowing the hood to go up about a foot and was able to release the latch.
Step 1:
Unplug the wire that is attached to your hood latch. (I did this in a later step because I didn't know if I had to take it out or not, but it just gets in the way) Also remove the cable from the hood latch if it is still connected.
Step 2:
Remove the clips holding the top of the bumper on. You can take off the whole bumper if you want, but I was able to do it without and it wasn't too bad.
Step 3:
Time to start unbolting. I've marked off which bolts you want to remove. For the first picture you will want to do the same to both sides. There is also one last bolt I didn't get a picture of because of the location. If you follow the metal piece that goes straight down between the two fans, there is one bolt at the very bottom that you will have to remove.
(Can anyone tell me what that piece on the left is? Nothing was bolted up to it and it was just kind of there..)
Step 4:
Fairly simple part. There are a bunch of plastic clips that are clipped into the front bulkhead and bulkhead center. To remove the clips, you just take your pliers and press in the plastic tabs so you can just push it out of the hole. Some are hard to get to but it is possible to get them all out without breaking any. I only have one picture as this step is pretty simple to just look at and find all the clips. I believe most of them were to hold wiring down tight and there was one for the release cable. These are pretty much what they look like:
Step 5:
You are now able to pull out the front bulkhead and bulkhead center. They are welded together so they will pull out as one piece. Now is the part where you have some options. You can separate the old bulkhead center and attach it to your new front bulkhead or if you bought a new bulkhead center, you can use that. What I did was reuse the old center piece and had someone weld it on to the new front bulkhead for me. I have also seen people who have drilled holes and bolted it together. Unfortunately I don't have any pics of the welding or the final product, but I would highly recommend you triple check the fitting BEFORE you weld it. If you decide to bolt it together you can look at the pics in this thread:
http://forums.clubrsx.com/showthread.php?t=763158
This is what it looked like when I took it out. It looked like this when I put it back in too, except the front bulkhead was the new one.
This is to show how bad the metal had ripped where my hood latch bolted up to.
Final Steps:
To reinstall, you just have to bolt it back in. I recommend putting in the bolt on the bottom that you removed first, then bolting up the rest. Reattach all the wires/clips especially the clip for the latch release cable. Next you are going to plug your hood latch wiring back together. Before you bolt your hood latch back up to your new front bulkhead, remember to attach the hood release cable to it then bolt the latch in position. You might need to adjust the latch a bit to get your hood to sit flush.
Hopefully this helps some of you with this issue. If you would like to add on any information, or need my help with this, feel free to let me know.
1 - 20 of 38 Posts
Nice diy. Ill need this soon myself
And that peice ur looking at is for the stock intake i beleive. Theres a lower part that comes up amd sits beside the battery. Bolts to that.
Thanks. It is pretty straight forward to do. The welding would be the hardest part, its just nice to know what parts you need and how much work will be involved before hand.
I need this .. u put the bulkhead center is optional but u say they r welded together?? I need the part dat the hood latch bolts to,.so what do I have to order the bulkhead center? How would I get it bolted to the front bulkhead? Or are they one piece since u said they r welded together?
The upper/front bulkhead and center bulkhead have 3 "spot welds" that hold it together. I think its just heat pressed but whatever. If you want to re-use the center piece that runs perpindicular to the ground, you can use a chisel or something to break those 3 "spot welds". And if you cant weld, I did post a link above of how people have drilled holes and bolted the two together. The hood latch actually bolts to the upper piece that runs parallel to the ground. If that doesnt make sense, just shoot me a PM.
Oh.., I'll check out out tomorrow on my day off!!
kickass DIY. I have this problem and now I have an answer. Thanks a ton.
Haha, thanks man. :thumbsup:
What color does the bulkhead come with out of the box?
Is it black? or did you paint it black after receiving the part?
Please advise, it's very important to me...
Also, how difficult to separate the welding joint between parallel and the vertical bulkhead?
BTW, Love your tutorial thread
It is black when you order it
You can just drill out the welds, I used a regular drill and just put bolts in the new one. You can source out a special bit just for drilling out spot welds
where can i get the actual latch ?
Same place as you get the bulkhead piece, i used www.acuraoemparts.com
my original hood latch got torn u p just like the OPs pictures
How did everyone manage to get that last clip all the way down the center bulkhead next to the fan? Im breaking my wrist and fingers trying to push it out but i have almost no room? Any advice?
Nice writeup. Did this a while back but awesome for people to have.
Mine cracked and I replaced it two years ago.
Don't use your fingers! LOL try a flathead screwdriver or some needlenose pliers. Also you could try taking off the splash guard and reaching up from under the car-but when I removed my bulkhead i was taking off the radiator so I had the whole bumper off too.
*meant don't break your fingers lol
my hoods rattling nasty
thanks for this thread gonna do this ASAP
I just did this DIY today after much procrastinating.
I'm just having trouble with the latch now.The cable works fine and I'm just not sure if its connected right.
I seem to have it connected but don't understand how the latch is suppose to open.
Maybe I'm missing a spring that connects both off them together.
wow did you have king kong in the hood instead of the trunk? never seen this happen!
its not there, anyone know where i can get just the latch?
1 - 20 of 38 Posts
