1 - 7 of 7 Posts
Hey CRSX this is my first DIY write up i wanted to share with people that wants to install Foglights on there 2002-2004 rsx without cutting the bumper to make them fit
TOOLS NEEDED
1. Foglight Kit *obviously
2. Exacto Knife
3. Sandpaper
4. Copper Wire *They are strong and dont rust :)
Step 1: Remove Bumper >>http://www.youtube.com/watch?v=uNpINnCfOfY
Step 2: Cut out the black foglights covers from the bumper with the exacto knife or dremel *whichever works best for you*. Then you take the sandpaper and sand the edges of the foglight hole you just cut out
Step 3. Insert 4 screws halfway in the bumper holes*green circles*, then place the foglights from the BACK of the bumper.
[/IMG]
Step 4. Curve the copper wire clockwise or the letter P * purple* around the screws that were halfway through. then you position your lights and tighten the screws with the wire surrounding it
[/IMG]
Step 5: Wired black wire to ground and the other wire to the DRl *No Switch
BEFORE :
[/IMG]
Finish Product with Black Housing Headlights
[/IMG]
[/IMG]
It's just Teflon...
This has been done before. At last you can switch to brake ducts if you ever get tired of fogs
1 - 7 of 7 Posts
