1 - 20 of 150 Posts
Sidemarker Mechanic
DIY JDM Door Visors, installed the correct way without removing any screws or clips. This DIY guide does not apply to WeatherTech or Door Visor Replicas as the steps to install them only takes double sided tape without clips.
Difficulty:
Easy
Tools Material Needed:
- JDM Honda Access Door Visor
- Small Pinch Tool
- Patience
Time:
- 5 to 15 minutes
Difficulty:
out of
Step 1: Roll down the window and make sure you are doing it at a well-temperatured time. (We want the 3M doublesided tape to work well.
Step 2: Pull down the inner Weather stripping, try and not to remove it all the way, just enough to clear the back clips.
Step 3: Now that everything is ready, without removing the 3M doublesided tape, test fit it first and find out. This is where you insert the JDM door visor clip through the mirror gap.
Before:
After:
Step 4: Insert the first front clip and putting it on the outside
Step 5: Put the rear clip inside.
3rd clip
Last, 4th clip
What it should look like underneath
Step 6: Now that everything fits in perfect, time to clean the area. Use the Alcohol Cleaning Pad provided in the JDM Visor and clean the area throughly
Step 7: Time to remove the doublesided tape cover. Remove just the front.
Do this to the back one.
This is how it looks like when you install the JDM door visor
Once Everything is aligned and clipped on, remove the tape and push down
Dont forget the rear
Finish Product
I hate my car.
I couldve used this like 2 weeks ago :p Nice write-up btw. When I was putting mine into place, one of the clips was loose and fell under my seat. Took me so fuckin long to find it ><
Reactions: lONE
Sidemarker Mechanic
Discussion Starter · #8 ·
i will edit the details and grammar later, i just re-read my shit and i feel i need to make some minor changes.
Rob_03 said:
does it help any with wind noise ?
yup no wind noise at all
I mean, this guy...
nice write-up and pics. I was thinking about these getting but $200 is a bit too much. I thought they were like $100 for the pair :( who knows maybe ill get them later down the road
Sidemarker Mechanic
Discussion Starter · #20 ·
someone is using this DIY on another forum without my permission?
1 - 20 of 150 Posts
