going to get a switch and do this, when i put my stock seats back in when i take out the recaros.
SRS light does not keep you from passing (in Texas at least)So i just bought a rsx and the guy before me had aftermarket seats then put the stock seats back in the car when i bought it. How do i reset it so the srs light can go off i needa get an inspection soon lol
Hmm ill give it a shot again tomorrowI just want to add that I just an RSX 02 and the SRS light was on and tried this method and it didn't work. The SRS light would turn back on after the 2 flashes of the SRS light.
I read thru a few pages and saw that one member mentioned that he pulled the keys out right after the 2 flashes of the SRS light turned, and finally it worked!!
Thanks guys! I know its an old thread I'm reviving.
Check the passenger side, remove the 4 14mm bolt that secures the seat down, lift it up and check the plugs to make sure they are fully intact and no exposed wires are showing. Side airbag can also be caused by the sensors on the passenger seat. Have you ever got the seat replaced? Just trying to see if I can point you to the right direction. Let me know what your results are. If everything is fine, try doing the DIY and see if it clears.Help! I've had my passenger seat belt changed about 8 times since I bought my 2005 Acura RSX brand new (Automatic transmission) and a few months ago the stupid (bright as hell) "Passenger side Airbag is off" light came back on!! This time the dealership said that my computer has gone out and just for the computer it cost $855 dollars!! I will not pay that!
Is there anything I can do to get this Airbag light off??
Oh yeah, what is the item number for the resistor that Radio Shack sells and can I buy it off the web somewhere? Will it help me? I can't stand this damn light being on anymore! It's been like a month or two now... Ahhhhhh!
Thanks in Advance!![]()
Yeah, I've already looked under the passenger seat (original Acura Factory seat) and everything is hooked up. I didn't take the seat out because I can see everything under it. When my AirBag light used to come on I would take it to the dealership and they would replace the seatbelt part near the seat next to the console. That SRS light would come on at least twice a year ever since I bought this car brand new (had 8 miles on it when I bought it) and they would always fix it by changing that seatbelt part. Funny thing is that the light would come on and no one ever rides in the passenger seat (LOL, No friends... pretty sad huh?). So this last time the SRS cane on I took it back to the dealership and they kept it all day long then called me and said the Airbag computer has went out (kaplooey)! It will be $810 dollars (I think it was 810 or 850) and I didn't even ask them about how much the labor is. I can't even afford the [email protected] computer much less the labor. Sooooo they said I have no AirBags that would go off if I got into a violent wreck.Check the passenger side, remove the 4 14mm bolt that secures the seat down, lift it up and check the plugs to make sure they are fully intact and no exposed wires are showing. Side airbag can also be caused by the sensors on the passenger seat. Have you ever got the seat replaced? Just trying to see if I can point you to the right direction. Let me know what your results are. If everything is fine, try doing the DIY and see if it clears.
Let me see what I know to see if it can assist you.You should see the list of the problems that I'm now having with my RSX! It's 2 pages long... I've always taken car of my .car (along with everything else I buy) but this is ridiculous!
Here take a look....
" #1: Passenger side "Airbag Light" is on, y'all have changed the seatbelt connection near the seat next to middle console to fix it... (Nalley Acura said my Airbag computer is shot).
#2: "Maintenance Required" light flashes three times after all other dashboard lights turn off???
#3: While sitting at the bottom of a hill at a red light when light turns green and I start off giving it gas the engine/front end vibrates and makes a loud roaring noise. I think it has something to do with vacuum or air intake? A bolt has worked itself loose on the big hose at the front and behind the radiator, you can see the screw that we put in to keep that pipe stable but I don't think it's holding the pipe tight enough.... (The Toy Shop said that my Transmission mounts are busted, along with my Motor Mounts)
#4: While cruising down the road and I have to let off the gas because someone is turning right off the road in front of me, when I hit the gas again I sometimes hear this loud THUD coming from under the engine/under the car where the gas and bake pedals are... (No answer from The Toy Shop about this problem).
#5: While slowing down to stop on the road, if there are ripples or multiple bumps in the road my front struts/shocks will pop, kinda sounds like Rice Krispies popping but way louder... (The Toy Shop said that the front Struts are shot)
#6: Car does not sit level, if you look at my car from the back it looks to me like the whole side (I think it sits lower on the drivers side) of the car from the front to back sits lower. You can measure from the Center of the wheel to the bottom of the wheel well and measure just how much further down one side sits while parked. It's always been like this ever since I bought it from y'all brand new... (The Toy Shop said that my front Struts are shot)
#7: Window washer hardly works anymore, the drivers side sprays great but the passenger side and back window washer just barely trickles out. I guess the pump is going out! Ahhhh!
#8: There is probably more stuff wrong but I can't think of it right now. :'(
My Acura RSX is the Automatic transmission, 2005. I have 92,399 miles on it. I got lots of extras on my RSX when I bought it (I.e. ground effects, Back wing spoiler, on top at the back of my hatchback, transferred my 5K Stereo system into my RSX my audio system has been transferred from 5 different new cars that I've owned over the years, etc, etc....). ;-)
Sent from my Nexus 5 using Tapatalk
