DIY: IMRC Delete Circuit P0661 P0662 P1077 P1078 etc.
34518 Views 40 Replies 20 Participants Last post by  osXFan
6
Currently testing a simple circuit prototype that allows the use of different intake manifolds on the base RSX without throwing engine codes. The circuit can be made in under an hr with a soldering iron and $11 in parts from amazon, ebay, radioshack or other electronic component retailers.
I will be logging 1k miles over the next week with the PPA manifold, and hope to switch over to a TSX manifold that I've modded for fitment (with base TB) over the weekend.
Results and a full DIY will be posted when completed/field tested. In the meantime here's a teaser image of the circuit itself:
Edit 18MAY2014:
IMRC Circuit MOD1 (based off schematic above):
TSX IM test fitting:
19MAY2014
TSX IM 80% installed:
90% installed:
20MAY2014
Test drive was a success!
I'm currently looking to source compatible plugs for the IMRC emulator for direct plug and play installation, if anyone has any tips on where to find the 2-pin solenoid plug and 3-pin IMRC sensor plug please do tell!
41 - 41 of 41 Posts
the day after installing the codes for the IMRC are no longer pending or active, they are stored, no code wipe was done.
41 - 41 of 41 Posts
