241 - 243 of 243 Posts
The big harness with the small yellow ring is factory. The smaller black wire is mine and delivers power to my DRLs. You can poke through the grommet/seal easily. But do it slowly and carefully. Take out the glovebox on the inside and get to it from there.
So with this being done I want to just verify so I dont make any mistakes, I can still use the button to turn them on and not have them on when I have the low beams on?
bleep-bleep bleeeep
No. I did this with my 'city lights'. They are the two tiny bulbs in the corner of the lenses. I wanted them on with the key; no switch. I suppose you could do the same with fogs or auxiliary lights. It just depends on how many amps they draw. You'd have to find a power source and use the correct sized wire, switch, and fuses to protect from fire.
