Status
Not open for further replies.
1 - 20 of 21 Posts
as the title says..
this is on an 05 type-S.
about 3 months ago i was driving on the interstate and accidently mis-shifted from 6th to 3rd and my RPM went waaay up to about 9500rpm for about 2 seconds.
ever since then, my ivtec just doesnt seem to pull as hard as it used to. i dont know if im just used to the car now or what, but my butt-dyno says it feels a loss of power.
the car idles fine and everything else, and i dont think i hear any pinging going on, just doesnt seem to pull as hard and when i turn off the car since this happend, it kinda rumbles a little, instead of just cutting off smooth and straight like it used to..
ive been trying to find the specs for doing a valve adjustment on this engine(its a k20z1, right??) but i even called acura and kept getting voicemails..
i want to do it myself, ive done a valve lash on a b18b a few time so im pretty familar with the procedur, but i dont know which arm of the feeler gauge to use(ie. .024mm?), and im pretty sure you start with piston #1, then 3, 4, 2, cranking the engine 90 degress after each adjustment?
HELP PLEASE!!:dontknow:
G
Unless the valves are making noise (don't be distracted by injector noise), they don't need to be re-lashed. However, I do agree that a compression check is in order. Good luck.
if i were you , i would
1) learn how to drive a car with a manual transmission
(your best bet is Gran Turismo, just go to the section where you choose AUTO or MANUAL)or (you could go to your local arcade and play cruisin world only you wouldnt have a clutch but you could guess)
2) not tell anyone how i have no educated down shifting ability
www.magtuning.com
This reminds me, lately from a stop, I find myself putting the car in 3rd instead of first gear
The first time I did this, i was literity spooked, I thought my clutch has died because I was BARELY moving :rotfl:
then I was like, oh..wtf.. :vtec:
1 - 20 of 21 Posts
Status
