1 - 15 of 15 Posts
ive check edos sig the first line says:
Mystery mod(s) worth an additonal 30hp! - ~250 dynojet whp / ~165 wtq
what is that? Mystery mod(s) worth an additonal 30hp! :D
!!!Master Member!!!
i saw this a lil while ago actually. i also was woundering what it is but i'm sure edo is doing some research otherwise he would have posted about that on here. hope its something not very expensive. then again its 30whp. cant wait to see when he will tell me
i thought he was just being sarcastic and attributing that 30 extra hp for it being on a dynapack or something....i dunno maybe im wrong
Rage With the Machines
electric supercharger?
Old member
His "mystery mods" are indeed actual mods to the car. Not just different dynos...LOL.. :)
He's got my special flashlight reflashed ECU fuse. You pull your ECU fuse, send me $99 along with your ECU fuse. I flash it with my flashlight, send it back to you via fedex next day air (No guaranties b/c fedex is always late) and install your newly reflashed ECU fuse. Bam, 30 extra WHP. Only $99.
I also reflash headlight fuses. Guarantied to be just as bright as HIDs in high beam. Those are only $55 each headlight fuse.
some guy
what kind of payments do you accept?:laughing: :spin:
I'm guessing you're referring to the "electric superchargers" you see advertised in Super Street, etc. Those boat bilge pumps are nothing more than a scam to screw you over. On the other hand, the E-Ram electric supercharger will actually produce .5lbs of boost, but will act more of a limitation for the engines found in the newer generation vehicles.
Back to the mystery mod, I think the best theory so far is the increased displacement statement. That's my best guess also.
Guys it's not a 2.4L that gave him the extra 30whp. According to edo(I specifically asked him what the mystery mod was) and he said it was the JRSC running 3.5lbs. But I'm sure when the right cams come out, we'll be able to make that all motor on a dynojet:thumbsup:
thats wierd because I distinctly remember him posting in his "Sneak Preview" thread that it was a larger displacement motor.
1 - 15 of 15 Posts
