1 - 4 of 4 Posts
Hey guys, I have a 2002 rsx and it has a problem with the dome light. When I opened the driver's side door, the light doesn't turn on. However, when I opened the passenger side, the light turns on. Which is pretty weird, I don't think it's the fuse. It could be the wiring? Idk I haven't checked the wiring yet because it's too dark to do anything right now. Any idea?
likes to troubleshoot
It could be bad wiring but more likely a bad door switch.
The switch is just below the striker. It has a black rubber boot over it and the door closes against it. You should be able to pull the boot off to access the switch. The closed (shorted) position is door open. The wiring diagram is in the Helm on pg 22-172 and 22-184.
1 - 4 of 4 Posts
