1 - 3 of 3 Posts
2002 Acura RSX Base
Hello! I was wondering if anyone knows how to fix this. Almost every time i open my cars driver door, the door catches on this piece of plastic that is coming out of the backside of the fender. It makes an incredibly loud pop and i don’t know how to fix it. I have a couple photos to show the piece, and how it’s getting caught!
06 RSX Type S VBP 06 RSX Type S Milano Red
There is a tab on the bottom and top of the back of your fender that goes in a slot opening to that plastic piece and it must have come out the bottom. You can remove your fender and put the tabs back in and put a retainer clip in to hold it as the tabs and slot openings have a hole in them. That plastic piece is there to keep water from coming into your doors
2002 Acura RSX Base
Thank you so much. I looked at the piece, realized i’m missing both of the tabs that hold in so it wasn’t in the right place and bent the plastic. gonna have to bend the plastic back in place, bc it must’ve been a problem for a while, bc it completely bent almost half of it in between the door and fender. But again, thank you!
1 - 3 of 3 Posts
