1 - 8 of 8 Posts
BECAUSE! racecar...
So i just got my car back from the audio shop and everythings working perfectly
fine. They bypassed the video lock on my indash player. But now when im trying to
lock my door it wont lock... It locks when the key is in the ignition while turned. But
when im in the car and there isnt a key ignition the door wont lock when i pushed
the button. So you can rule out a problem with the remote. I doubt the battery is
the problem because the lights work fine. If anyone can shed some light on my
issue itd be greatly appreciated. Maybe its as simple as a fuse blown but that is
all i can come up with. I tried searching but theres too many door actuator
problem threads. I tried to make this diagnosis as detailed as possible so if
theres something you think i havent check feel free to chime in.
referred to Subaru
is it both doors or just one? also when you mentioned that it locks with the key in the ignition, what method were you using to lock them?
the fix may be as simple as your remotes being reprogrammed but you left out some info.
BECAUSE! racecar...
Its either all of them lock or none of them lock...Its not the remotes because I sat in the car without the key in the ignition and pushed the button and no dice. When i put the key in and turned it the doors were able to lock.
referred to Subaru
well it is the remote. the car no longer recognizes them. you'll have to reprogram them. when this happens it usually means someone entered the remote program sequence using the key in the ignition.
BECAUSE! racecar...
When im in the car why wont the doors lock when i push the button? That doesnt involve the
remote whatsoever.
BECAUSE! racecar...
have you dont anything electrical to your car that might of popped a fuse?
The audio shop might have...If so which fuse would i have to replace for my problem?
BECAUSE! racecar...
Discussion Starter · #8 ·
Fixed....Was just a fuse....
1 - 8 of 8 Posts
