1 - 7 of 7 Posts
So i've had this problem ever since i got my 03 rsx about 6 months ago. The driver's side lock can only be operated manually. The remote and the lock/unlock buttons work for the other door and the hatch in back. When i manually push down the tab thingy to lock the door it also locks the others though so its not completely disconnected from the power. It just can't be moved by the power. I'm thinking it could be an actuator or something like that? Please help. If i could fix it myself that would be great...
Ive had that happen to me..my boy works at lexus and he fixed it for me..he told me it was not alligned right, i think you gotta take out the door panel and reallign it let me know if that works.
referred to Subaru
bad actuator. i just replaced mine 2 months ago, had the same issue. if you search there are quite a posts on this and a very good DIY.
I've been doing some research and I found these DIY's that might help
http://forums.clubrsx.com/showthread.php?t=346683
http://forums.clubrsx.com/showthread.php?t=556948&highlight=door+panel
and you can buy the part herehttp://www.acuraautomotiveparts.org/acura/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=RSX&catcgry2=2002&catcgry3=3DR+BASE+LEATHER&catcgry4=KA5AT&catcgry5=DOOR+LOCKS-OUTER+HANDLE&ListAll=All&vinsrch=no&systemcomp=List%20All&vinnoT=&trim=&trans=&view=normal
or from the dealer
Thanks for the help everyone
Thanks guys I got it fixed. I had to take it to a mechanic though. I tried to do ti myself but i couldnt get the latch mechanism out. Well it's fixed now
1 - 7 of 7 Posts
