1 - 3 of 3 Posts
That plug looks like your parking lights connector. I can't tell without more pictures or how the wiring is done from both sides. Since you don't have HID the connection should be the same without the ballast/ignitor. The low beam should go directly to your low beam connection from the headlight side to chassis side.
That plug you're referencing in the pic plugs looks like the one that's supposed to go in the headlight bulb. The OEM one is the same design, but a female piece. Is that another connector on the bottom left of the pic inside the headlight? Looks like it could connect there.
1 - 3 of 3 Posts
