1981 - 2000 of 2017 Posts
I think I had a similar issue when I upgraded to v4 but I think what I had to do cleared the calibration from the ECU. Wasn't an issue for me since I already had it saved. Let me know if you're willing to do that and I'll look in Kmanager and see if I can remember what I did
I've been playing around with it and I think that it might be because my Kpro is on V3 but my software is V4. I've been really busy with work so I haven't had much time to play with it. I guess I'm okay with clearing the calibration as long as I can get it to run. I'll probably take it to get tuned when I get it running.
Thanks for the help!
That makes sense.
Wonder if you could find an old v3 software version.
Then you could pull the cal then use v4 to re upload possibly. That way you don’t completely lose your tune.
Hello, Does anyone have the correct calibration data for the factory coolant temp sensor on the K20A2 for use on AEM Infinity? I am using the "out of the box" calibration and I believe it is off some. Thanks!
Deleted IACV.
Car won’t idle now just stalls unless I let rpm down gently it will idle around 400.
Idle is set to 900 in kmanager.
Does kmanager not set the idle when you delete IACV?
Few days after I installed my race header I got CEL P0171 I think it was, Running lean bank 1.
My question is... Is buying kpro or reflash the only way to fix the air/fuel. If I buy Kpro I wouldn't trust my self to try to mess with the ecu settings myself. Is there pre-made tunes I could load or just find a tuner & get him to do everything.
Currently only running rHeader/Exhaust.
Running without a tune for 3 weeks now, the CEL only came up 2-3 times
- yes or Ktuner
- there are several basemaps/reflashes available on both platforms, but getting tuned will provide you with the best results.
05 Type S RH Reflash LSD
Yes you should get Ktuner for 05-06, if you want it to be way cheaper
I am surprised you got a lean CEL for running a header though. The stock tune is so rich that usually this is only a problem if you have intake-only reflash, and even then, not always. You must have the best exhaust combo ever! lol
When does it happen, if you pick a high gear and floor it for a long time?
- yes or Ktuner
Alright, the Kpro is pretty pricey & I feel like I'll be diving into an ocean of options & possibly more problems downt he road (but I guess at least i'd be able to get it tuned however)
from my little understanding, Ktuner is the reflash & it's just reflashed based on my current mods right? (header / exhaust) & When I mix up my setup I'll have to get another reflash correct?
Another question, i guess would mainly depend on my tune but do most people end up switching to a better gas premium after their tunes? (ikno everyone has different cars, trim levels, mods, tunes etc..) but generally do most people switch up? I've only filled regular gas since it's a base model & I didn't do anything with the car for 3 years.
*As for Kpro I need a 02-04 ECU & the primary 02 sensor? what happens to my current ecu? or am I misunderstanding something *
Ktuner would be nice because cheaper, is it easier to get things setup? (I research and then forget most of the info :( )
2005 base 5spd with a heavy 270k on her.
I can't remember the last two times I got a CEL, but the first time me & a friend were going to drive out real far to pick up some used OZ wheels & sometime before we headed up there I got the Code P0171 (s/o to my new friend dennis with the scanner) anyways on the way back the light came off.
Other two times I'm not sure, but if I remember right, I think it was fine the next day.
I'm running K-Tuned race header & the matching 3" exhaust, so I think air is flowing real nice **stock airbox tho :rotfl: **
I can floor it WOT 1st, 2nd, 3rd & no code. Few pulls on the highway, rode 3rd gear all the way & 4th (in mexico) & I never notice a code (hoping it stays that way)
You can have either a reflash, or a fully tuneable ECU with Ktuner (End User). The Ktuner reflash isn't specific to any bolt ons, at least the one that comes with the software. I know Turbogixxer offered an I/H/E reflash, but I don't know about other dealers.
You don't need to run higher octane fuel unless the tune calls for it, like Hondata's 89 and 91 octane tune for the base. I use 91 octane just because I know the ignition has been advanced and our cars can knock on the stock calibration in high ambient temps. I doubt it's necessary, but I don't mind a couple extra dollars at the pump for peace of mind. Top end seems to like it too.
If you were to get Kpro, you would get the first gen ECU and do whatever you want with the stock one. If you have to smog bi-annually, keep it for emissions.
There isn't anything to set up really. You just plug in your ECU, connect it to your laptop, register it, and upload your calibration.
I recommend no more WOT until you get your fuel squared away. It's your car of course, but I see problems in your near future with mileage that high and throwing a lean code.
I think Ktuner (End User) is the path of least resistance (including money)
Also, I wanted to note that it came to my attention that bad/old/clogged fuel pump/filter could cause a lean condition, especially under max demand. Does it whine excessively at all? Could be on its way out
Kpro V4 Advice
I've got a 2002 Type-s with the skunk 2 alpha header, injen short ram intake, and a borla catback. I've been exploring the K-pro (v4) software, but im having trouble picking out the best basemap with the stock injectors. For anyone with a similar setup or would just know, which map should I use on my calibration? Thanks.
People have posted that you probably want to run the "Stock K20A2 with cold-air intake, dyno tuned" to start. It's too bad the Toda header one has the VTEC set at 3000rpm. Idk why it doesn't just come with a RH basemap that works for most people.
BTW, which basemaps are you finding with bigger injectors? Yours should be 310cc (base RSX is 270cc)
Wondering if anyone else is experiencing this...
I managed to keep my WOT AFR between 12.8-13.1 from 2000-7000 (A3) in 3rd gear, but I'm showing larger variances in other gears. Anywhere from high 11's to mid 13's. Is this normal with K series motors, or do I have a super secret problem waiting to bite me in the ass?
It's just a plain old A3 w/bolt ons paired to the auto tranny, tuned by Tkane on Ktuner with adjustments to the WOT columns made by me.
For anyone else experiencing a similar situation, check for an exhaust leak. My problem ended up being a cracked header.
NA Today
IronGumby's right, the stock K20A2 with cold air intake, dyno tuned basemap is a good place to start for you.
I'll keep that in mind for WOT, i've been doing pulls every now & then, few races against my buddy's mini :ugh:
I wasn't sure what you guy were talking about when you mentioned the end user but after looking on the ktuner site I understand a little more now. the Ktuner in-ECU (End User) is what seems like the best bet. It seems like KPro & this Ktuner inEcu(EU) do almost the same thing does it not? Few people have recommended Kpro in the past.
Leaning toward Ktuner.
I've never touched the fuel pump/filter since I've bought the car @ 230k kms :shakehead I was actually thinking this same thing with my fuel injectors.
Not sure if it's the same thing but I find my car to be lacking acceleration, I feel like I have to slam on the gas just to merge onto the highway or just even over take in the right lane at the lights... after driving my friends mini cooper, the throttle response is always great in every gear. I know it's a completely different car but I'd like to have that type of acceleration or even *Better than what I have now. I feel like I get most of my torque when I drop into 2nd around 3.5-4.5 rpms.
The tune will help with faster acceleration? maybe ditching the plastic intake manifold for the type-s RBC?
thank you for the help guys
It's lacking acceleration because it's an A3 with long gears. The tune will help in every aspect, but it won't feel like your friend's mini lol. Keep your plastic manifold. It uses long narrow runners until 4700 rpms, and then switches to short wider runners until redline. You'd lose torque with the RBC, and I think it would only make more power in the top end, which we don't have much of due to the 6800 rpm rev limiter.
Start with getting a tune and see how it feels after that.
:iamwiths:. Also, nhbp.rsx, the Type S intake mani is the PRB. PRC is the Type R. RBC is the Civic Si. But regardless, mfarmakas is right.
You need a tune to feel that header working! Or at least get the most out of it. As long as it's not a shorty
Thanks the info guys, I was going to go with Ktuner but I got one more question.
If you go with Hondata's K-Pro & I find a 02-04 ECU(Not sure how easy or hard this will be tbh), I'd be able to keep my original ECU laying around incase I'd want to re-use it if the car was to be sold or something along the lines? Does it work like that? Freely swapping out ecu's & going back to stock?
There was a big sale on Ktuner & Kpro last week I should have hopped on that Ktuner, would have saved a bit of money smh...
RN Ktuner would be 680, & KPro 1100 Canadian, currently too broke to buy anything for now. Had to cough up some cash here & there, and then go tot a shop to cut out seized lower bolts from my struts for the rear coilovers & then alignment
The major hiccup/hurdle/problem with having multiple ECU's is that you have to have them reprogrammed to your immobilizer to switch each time, no? Someone correct me if I'm wrong
If you really wanted Kpro you will need the ECU wiring harness adapter and the 02-04 primary oxygen sensor too
