Hondata is pointing out the two wires that come from the ECU board to the manifold. The so called 'grounding kits' do NOTHING to improve this specific path. Anything to the battery ground does not improve current return path while the engine is runnning since the alternator/ its mounting bracket is the source of + voltage & thus the return path has to be good going back to it.
If the two ground wires to the manifold are loose or corrosion starts to impair the current path then when that current is shunted to the ECU case thru the body that current could damage the circuitry on the board.
If one removes those wires to install the IM gasket then one must assure that the connections are tight.
I have seen a couple year old never disturbed grounding bolt on the engine block directly to the ECU, have corrosion under it such that the ECU controlled fuel pump relay would not activate & thus the engine cranked but would not run.
I question the redirecting the wires to the valve cover instead of the manifold since the torque of the bolt on the valve cover would be less than to the thicker metal of the manifold. Also, the aluminum valve cover expanses & contract more than the steel bolts thus tends to loosen the bolts.
