1 - 20 of 28 Posts
K20A2 EP3
EP1 (Europe) D14Z6
NON-VTEC ENGINE
Engine Size: 1.4 L
Cylinders: 4
0-60 mph: 11.5 seconds
Horse Power: 88
Valves: 16
Torque: 95 lb-ft
Comp. Ratio: 10.4 : 1
EP2 (Europe) D16V1
V-TEC ENGINE
Engine Size: 1.6 L
Cylinders: 4
0-60 mph: 10.3 seconds
Horse Power: 108
Valves: 16
Torque: 111 lb-ft
- SOHC V-TEC
- Shares parts with D17A1 and D17A2.
- Intake manifold is plastic
- Downdraft throttle body.
- Exhaust manifold is in the front and the intake manifold is in the back (unlike k-series engines)
EP3-R (Euro Type R) K20A2
I-VTEC ENGINE
Engine Size: 2.0 L
Cylinders: 4
Horse Power: 197
Valves: 16
Torque: 145 lb-ft
EP3-R (Japan Type-R) K20A
I-VTEC ENGINE
Engine Size: 2.0 L
Cylinders: 4
Horse Power: 220
Redline: 8400 rpm
Valves: 16
Torque: 152 lb-ft
Comp. Ratio: 11.5:1
Transmission: 6 speed
EP3 (US) K20A3
I-VTEC ENGINE
Engine Size: 2.0 L
Cylinders: 4
Horse Power: 160
Redline: 6800 rpm
Valves: 16
Torque: 132 lb-ft
Comp. Ratio: 9.8:1
Transmission: 5 speed
EP4 (Europe)4EE2
COMMON-RAIL TURBODIESEL(NON-VTEC) ENGINE
Engine made by Isuzu
Engine Size: 1.7 L
Cylinders: 4
0-60 mph: 11.2 seconds
Horse Power: 100
Valves: 16
Torque: 162 lb-ft @ 1800-2800rpm
Comp. Ratio: 18.4 : 1
FREQUENTLY ASKED QUESTIONS:
What's available in America?: Only the EP3 equipped with a K20A3.
Is there an EP3 Type-R in America?: No.
What series engines do the EP1 and EP2 have?: They have D-Series engines.
What series engines do the EP3s have?: All EP3s including the Type-R run K-Series engines.
I have more information you should add to this post!: Reply with said information or PM me and I'll add it.
ADDITIONAL MISC. INFORMATION:
  • Some after market parts for the EP3 can also fit the EP2.
  • Some of the body kits for the EP3 will also fit the EP2.
  • The head lights on all UKDM EPs are the same (except for models with projectors)
  • The EP3s suspension is not interchangeable with other EP chassis.
  • The EP1 and EP2 have four lugs, the JDM and UKDM EP3 have five lugs.
  • EP3 brake rotors will not fit into an EP1 or EP2 (because of the lug pattern)
If anyone has anything else I should add, let me know.
576hp/506tq FTW
bump... i think this one should be moved to the bolt on basics section and maybe copied to the all motor section also... but imo, this should be somewhere easy to find and read...
ride height Nazi
Define a k20a.....A lot of people have gotten burned on ebay with k20a's....any k20 motor in the jdm is a k20a.....even the strange type-s motor and the base dc5 motors have k20a stamped on them....so be careful....:noes:
ride height Nazi
Yea, the jdm type-s motor has "real vtec" on the intake side and a ep'sh exhost cam....made like 190 crank hp.....there is a thread on some guy that got one over crsx a couple of years ago....he thought he was getting a type-r motor.....:thumbsdow
hey there guys.
just read over your post searching some information for interchangeable parts of the D16V1 and D17A2 engine (which are sharing some parts and seem to be very similar).
I can provide you a self taken picture of my European EP2 D16V1 Engine.
So here you are...
edit: the header has been changed on this pic - so its aftermaket not OEM.
1 - 20 of 28 Posts
