1 - 3 of 3 Posts
Been Around for a while
Will be mounting an EQ if I can find a stealth location.
Any ideas?
The Audio Guru
What kind of EQ, I'd suggest a DSP as if you go the EQ route in order for it to affect all speakers you will half to be using external amplification and at that point might as well get the benefits of full time alignment and be able to run a fully active setup. most DSP units are small enough to fit under a seat then you can plug your laptop in and adjust away.
I completely agree. I will add the DSP later ($$$) Thanks for the advice.
1 - 3 of 3 Posts
