1 - 4 of 4 Posts
· Registered
Hi!
I'm have a race car without stock cluster.
My only gauge will be Defi "computer" with all informations in it.
And i'm little nervous about water temperature sensor.
Somebody put it in place on the photo.
I know that the stock sensor is in the bottom of radiator.
Do you think that this additional sensor shows real temperature or lower or highier?
Thanks for any help!
· Super Moderator
It has a range of 196°-203° but that’s ok. Your sensor is reading the temperature of the coolant that is flowing out of the engine and into the radiator, not what has cycled through the radiator. You can test the fan switch if you’re worried that it’s not working. There’s a quick procedure in the service manual.
1 - 4 of 4 Posts
