1 - 5 of 5 Posts
I have a 2004 acura RSX type S with A K24A2 and kpro v4
When I turn the AC on the fans do not come on but compressor comes on.
Radiator fan and condenser fan only come on when the radiator switch comes on at 208f or if I jump the Connector then stay on alway.
Both fans are good, seems all relays and fuses are good. Unless I'm missing something.
In the Hondata it says they're supposed to be on but do not come on or if I force the fans to come on they do not come on.
See 10-14 in the manual found in the sticky section. You can check for DTC and troubleshoot the system from there. Did you switch any of the relays around?
1 - 5 of 5 Posts
