1 - 2 of 2 Posts
Airbag sensor error
The airbag sensor circuit will operate the day it starts the vehicle. Let's take a look at the various signs that make the airbag sensor light blink.
The airbag battery is empty
Battery out of air bags is still one of the main signs of a bag failure. The air bag battery runs out of electricity when the vehicle battery runs out. This problem often causes the sensor light to blink. But to solve the problem, you only need to recharge the car and the sensor light will not blink anymore.
Defective airbag coil
Airbag coils help maintain the connection between the airbag and the steering wheel. This coil is responsible for controlling the power supply between these two parts. When the coil constantly contracts and expands, it will corrode over time. This causes the airbag sensor lamp to glow on the dashboard.
Diagnosing this problem by yourself is not easy. Therefore it is recommended that you take your vehicle to a reliable repair location and replace the new sensor lights.
This is a complex matter and will not be able to fix it on our own, it needs expertise from the automotive industry. In order to avoid any incidents, I agree with this idea.
1 - 2 of 2 Posts
