1 - 5 of 5 Posts
When I first bought my Type S, it had 18" Axis Speed Six rims and pretty heavy tires. Best I ever ran (two races) was a 16 flat at 88 mph. I swapped out the heavy ass rims for stock wheels/tires and installed an Injen CAI. Ran 4 times this past Saturday. After first two runs, I lowered my PSI to 28 in front. Here is how I did.....this is in Phx with ambient in the 80's and very low humidity. I believe altitude is around 1000'. This was with no weight removal and I weigh ~220 lbs.
RUN 1 RUN 2 RUN 3 RUN 4
REACTION- 0.655, 0.179, 0.144, 0.080
60' TIME- 2.639, 2.605, 2.543, 2.498
330' TIME- 6.946, 6.804, 6.697, 6.642
1/8 TIME- 10.318, 10.138, 10.034, 9.975
1/8 MPH- 72.94, 73.07, 73.54, 73.58
1000' TIME- 13.198, 13.002, 12.892, 12.83
1/4 TIME- 15.647, 15.436, 15.334, 15.269
1/4 MPH- 92.01, 93.2, 92.39, 92.5
Comments/Suggestions???
Lower your psi to around 22-25 and get your 60ft time down and you'll be the in the 14's. People would always tell me that, and I didn't believe them until I tried, and I ran a 14.85 with 19lb wheels and only a CAI. Also next time you go try it with all the back seats, spare, sub out etc. Practice makes perfect :thumbsup:
Thanks for the advice. I'll try the 22 PSI next time. If I can cut .2 off my 60', I should be around 15 flat or high 14's. This is fun as hell!! Especially for a 50 year old. :driving:
Haha ;) gotta start sooner or later. Good luck. If it comes down to it, a simple switch from stock tires (if you have the normal RSX stock tires) to something a bit more sticky, and you can easily knock down your time. :thumbsup:
1 - 5 of 5 Posts
