1 - 5 of 5 Posts
Hey hows it going.... I've been hearing all kinds of wierd "probly not good" sounds coming from my car latly... changed the brake pads and rotors and alot of it went away. But i am still hearing this squeak squeak sound which appears to be coming from the front passenger suspension side. I hear it when i turn sharp or after the car has been used for awhile i'll get out of it and sit on my front driver side fender and go up and down on it and it will rattle/squeak? Some people say it can be my heat shield... or some rubber that has cracked that was holding oil in it... can't remember the name of the part he said. Anyways any info would be great since when/if i bring it is would be cheaper if i knew what it was compared to 109$/hour inspection fee lol...
Señior Memberish
I would just start lubing one suspension component at a time.
Start with the control arm bushings, lube with red grease or white lithium.
move to end link
move to tie rod end
move to ball joint
that should about isolate the squeak and what you would need to fix, or just keep lubing.
GT30R > Traction
what type of suspension are you on?
GT30R > Traction
heat sheild is over your header, grease you suspension.
1 - 5 of 5 Posts
