1 - 2 of 2 Posts
So my front windshield washer is not working. Every time I try to use it, the windshield wipers fuse blows. The rear windshield washer works though. It's probably the motor but I'm confused on which one to get. I looked at acureoemparts.com and there is two motors. One that is just called "Motor, Washer (Mitsuba)" and another one called "Motor, Washer (High) (Mitsuba)". Which one do I need for the front windshield washer? Does it matter? Here is the link of the diagram.
https://www.acuraoemparts.com/auto-parts/2006/acura/rsx-hatchback/base-trim/5-speed-automatic-engine/electrical-exhaust-heater-fuel-cat/windshield-washer-1-scat
Vaginal Lubrication Tech
23 is for the front winshield
24 is for the rear
if you wanna check to make sure its the motor and not a short in the switch or the wiring, you can:
unplug the washer motor and then replace the blown fuse.
(IGN switch= ON)
Now push the washer switch a few times, then check the fuse.
If the fuse is blown, the problem could be :
bad switch
bad multiplexer (not likely)
or you have a short in the white/blue wire that goes from the washer motor to the multiplexer.
1 - 2 of 2 Posts
