How many miles? It could be the synchros
(was mine anyways @ 77k miles)
How many miles? It could be the synchrosOnce in a while when im ripping on my beautiful baby at WOT and redlining sometimes when shifting into 2nd or 3rd (also seems to happen more on sharp turns) I go to throw it in gear only to hear the gears grinding. Once paused for a second, rpms lowered a little it will go into gear. Now my question is, am I just getting overly excited through the ride in VTEC and am just slightly missing the gear or is it the 2nd and 3rd gear grind thats popularly known. The clutch is deffinetly and always completely engaged so that option is eliminated. This never happens in the daily driving though. Thnx for any Info.
How about READ. All the grind topics didn't specify how or when it happens I thought maybe I was getting happy with the stick when racing wasn't sure if it was actually the same issue every one else was having because it never happens during normal driving.search...
I would def recommend a tranny service...def85k miles
Stock Floor mats except for winter and i throw in the rubbers.
There was a previous owner(Apeared to be a golfer(found tees in with the spare)and was bought from west palm beach).
Guess I could do a tranny flush.
Dont have a digital recorder![]()
Deff on the to do list. Ill let you guys know results.I would def recommend a tranny service...def
just out of curiosity did you change your tranny fluid out by yourself? how hard is it?Try changing your fluid out first like JPSlick said. I am currently using Amsoil MTF and it elminated my 3rd gear "hesitation" that most 05/06's get.
GM synchormesh is another good MTF people on here use.
Yes its the major reason for grinding gears. also the JDM cup holder causes wheel hop if you dont use loctite.Not to sound rude but what does a floor mat have to do anything with gears grinding?
Dont diss JDM yoo there glass= 20HPYes its the major reason for grinding gears. also the JDM cup holder causes wheel hop if you dont use loctite.
Why what do you consider a mod? I've seen redouts as a mod. I thought a mod was anything that you modify on the car?ok. i really cant hold this in much longer but seriously. chromed headlights ARE NOT a mod. LOL.
