1 - 2 of 2 Posts
i have a skunk2 70 mm throttle body and im on number 5 omni tps what is the voltage i should be settin it at because .45 volts at closed throttle is fine then when u go wide open throttle is read OFL i need to go a little lower in volts what the lowest im able to go without throwing a code
1 - 2 of 2 Posts
