Yeah , I was looking into ...but actually I already have the wheels at Home ��I would go +35, +45 doesn't car the rear trail arm. There's a whole thread on this if you searched.
I seeLots of people have a 245/45 or 245/40 tire all around with the +35 on a spring drop. You'll need to roll the rear fenders.
Whats your camber like and are ur fenders rolled? I have 255/40 on 17x9 rolled fenders and only -2 camber with a one and a half finger gap. I dont rub whatsoever at all even on bumpsI have RPF1 9in +35. The 255/40 will rub a bit rolled and look a bit big too me--also I can't lower as much due to width. They look beefy and are wide, so if you like that look it's cool. I have 245's waiting and will cure all my woes. Just a bit narrower and I can drop just a bit more.
You have pictures of it .. ?I have RPF1 9in +35. The 255/40 will rub a bit rolled and look a bit big too me--also I can't lower as much due to width. They look beefy and are wide, so if you like that look it's cool. I have 245's waiting and will cure all my woes. Just a bit narrower and I can drop just a bit more.
Any pictures of it ?Whats your camber like and are ur fenders rolled? I have 255/40 on 17x9 rolled fenders and only -2 camber with a one and a half finger gap. I dont rub whatsoever at all even on bumps
Manufacturers aren't always spot on so maybe these are wider . I'm running RE11's and they have some grooves from rubbing even in the front. Maybe you have more preload as well. Just a little more camber could go a long way. I hate to play too much as it's solid as hell as far as handling. IDK, but I rub rolled.Whats your camber like and are ur fenders rolled? I have 255/40 on 17x9 rolled fenders and only -2 camber with a one and a half finger gap. I dont rub whatsoever at all even on bumps
Il take some when its not snowing here lol. GotchaAny pictures of it ?
Hmm, are your fenders rolled tho? And i wouldnt go past -2.3 camber in the rears at all. Fronts im at -1.5 rear im at -2. Maybe it could be the preload. But it would have to take a serious pot hole for me to hear the rub. When i go slow up entering a driveway i domt rub either. I dont have pics arm like the lerson above mentioned but il take some when ihave the time, today was a snowstormManufacturers aren't always spot on so maybe these are wider . I'm running RE11's and they have some grooves from rubbing even in the front. Maybe you have more preload as well. Just a little more camber could go a long way. I hate to play too much as it's solid as hell as far as handling. IDK, but I rub rolled.
