1 - 20 of 35 Posts
Murderator
See sig...and this is with Intercooler...No 1/4 times yet....
Impressive numbers Arcticblue.
vashuba311, I have a friend who is also running the GReddy kit on his Type S and has a boost level almost as high as Arcticblue's. On performance street tires, I've seen him run mid 13's consistenly.
nice numbers
vashuba311
thanks for the info.
Articblue- i noticed you ran 12 psi, can u run 12 psi safely because i haver seen a greddy ran at 12 everyone says 7-10
he said he had to shut his car down on the dyno at 12 pounds because it was leaning out......so no you cannot run on that boost safely.
I would love to see 1/4 mile times... I ran this weekend at the track and got a 8.9 in the 8th, but the car was soo capable of an 8.7 or maybe even .6 ... I was just killing my launch! I was on 18's+stock cat by the way.
K series tuning liberator
How did you launch that baby? I was having one hell of a time launching correctly without loosing traction in first-third. We barely get into third in the 1/8th. It was imbarrasing to say the least.....nasty burnouts though!!!! :)
riiiiiiight
Are you running a test pipe or the stock cat?
So what was your time teamrsx?
Murderator
That was with Stock cat
the best i could do was 9.9 in the 1/8th... no matter what i did it was too much...i even started out in second and feathered and still could not get traction thru third.....my best times N/A was a 9.2 in the 1/8th....but this is a whole new beast.
impressive #s for that kit. to bad it can only run safely at 10psi. im sure if you make some tune it more you can raise it a bit more.
:D frederick :mad:
:D frederick :mad:
With a simple upgrade to 550cc injectors and you can run 12+....but the internals would not hold up long.
Yo Arcticblue: Did you ever get your 550's in your car?
Murderator
nope...they are still sitting in a box.....
When you gonna get them bitches installed? :)
Murderator
when i have time to get down to a Dyno...the problem is that once i put them in i have to cut them back so i need to be on a dyno...
Your right! You have to be on a dyno so u can get the duty cycle right for the boost and fuel maps you are running. Let us know how it goes when you get to that point bro.
I'm right behind you, getting mine soon.
1 - 20 of 35 Posts
