1 - 4 of 4 Posts
My oil line that came with the greddy kit started leaking. it's leaking from where the steel braids go into the fitting. I replaced it with a costom made copper tubing one i made but i want something that can hold the pressure because it leaks where the copper tubing goes into the new fittings... yes i used teflon tape on all the fittings.
Anyone know where i can get one?
Welcome to the club! I had the same thing happen to me.
I went to a rubber specialty place where they fabricated a line that is the same diameter inside, but way thiner in the outside.
Just make sure that it can hold atleast 200 psi.
I had it made 10" longer so I could route it deferently
Buttplugs?
When I put my kit in, I looked at the oil return and thought; "My God...rubber!?" I just rigged a braided line back to the pan and have not had a problem with it since the install.
1 - 4 of 4 Posts
