1 - 20 of 23 Posts
EFI Tuning Professional
Stock internal type-s with basic bolt ons and stock intake manifold.
This was done on our dynojet, 1500 ft elevation, our 4-1 race header and 2.5" exhaust with a full tune using 91/103 octane mix.
Also, the car has some heavy 17" wheels, so numbers would have been slightly higher for both stock runs and after runs
Mikey
Zilla 4 Rilla ©rew #0
integrals?
That's wassup, nice numbers.
13.43 @ 105.43
nice numbers
N/A to go please...
Again, very nice numbers. :thumbsup:
Peace
WhiZ
rawr
Impressive numbers, but what does "with a full tune using 91/103 octane mix" mean??
RSX fanboy supreme
It means the possibility to add more ignition to the tune than regular 93 would allow.
Nice results.
Just imagine the possibilities with a highly-modded car with cams etc.....
Discussion Starter · #13 · (Edited)
Nice results.
got-type-sexy???: We will not dyno tune the 4-1 with hi-flow cat (should be about 5-6whp less), but we will offer it as an option.
I feel that this header needs the itr manifold to breathe its best. I already told the owner and he now will be purchasing an ITR manifold and in the future, IPS-k2 cams.
Also, our 4-2-1 will be re-designed in the next coming weeks for the type-s.
Also, since we are at 1500 ft in elevation, we think that at another dyno near sea level, numbers should be much higher
Mikey
Discussion Starter · #15 ·
Also, since this is a 4-1, it's meant for all out top-end, which some drag racers need. However, I was quite amazed with the flat beefy torque curve this header put down
Mikey
RSX fanboy supreme
So this car had bolt-ons before, then you swapped only the header and exhaust and full-tune for after results?
I would imagine that it had stock exhaust header before?
The gains are quite nice, not limited to any certain area a great deal.
I would really like to see your 4-2-1 header tested on this car also.
It would clear a very large test variable to use same car,dyno, and supporting mods.
These gains are way more than any other header on the market.
Congrats on results.
A quote from Hardcore's original 4-1 header thread.
HardcoreRsxS said:
Car was baselined in stock form and it made 164whp126tq
with cai, our race header, and our free flowing exhaust, we're up 31whp & 18 ft/lbs (car also had a bad batch of 91 octane fuel, ecu made me retard 2 degrees in some places due to bad knock), but after testing I found out that we had 2 exhaust leaks.
We've made the second design and we've mixed 91 with 103 octane.
Mikey
You never know, your 4-2-1 might just have a convex shaped torque curve instead of a flat one :thumbsup:
Discussion Starter · #20 ·
Killbam said:
So hardcore automotive is in the process of prototyping their own headers and exhaust systems?
We have finished the design and testing for the 4-1 on the type-s, 4-2-1 on the base and our exhausts have been done for about a week
4-2-1 will be tested shortly on the same type-s, but contact me @ [email protected] if you are interested in purchasing any of our products
Clubrsx does not allow unauthorized vendors to discuss pricing
I am hoping my welder can take care of the shop and do everything as scheduled while im gone for more training
Mikey
1 - 20 of 23 Posts
