1 - 5 of 5 Posts
I bought some headlights recently and didn’t realize they only fit stock bulbs. Anyone know of a way I can modify the housing to fit LED’s or would HID’s fit? Any threads where someone has done it before? I didn’t have any luck in my search.
You don't need to modify anything, just purchase the correct bulb. There's a shit load of H1 LED and HID kits on the internet.
I advise against the LED's though. You're visibility will be shit and you'll just blind incoming traffic. HID's can blind incoming traffic as well, but that's easily remedied by adjusting the height of the reflector bowl. Beam pattern won't be perfect, but not nearly as bad as the LED's.
The LED I have are H1 bulbs but the housing suggests I only use stock bulbs
That is certainly a confusing statement, never seen anything like that in a description for LED's... It might be referring to the "X" clip that our stock bulbs use to stay secured. Regardless, I'd return them unless you're ok with not being able to see properly at night.
1 - 5 of 5 Posts
