1 - 15 of 15 Posts
· Registered
Hi everyone, I am new in this forum. I have been reading this forum for a long time and i now finally a member. i hope I ask the right questions so someone can help me out. I just picked a 06 rsx type s a few months ago and she is sitting on my friends driveway. I just found out that there is no Heat. I came across that there is a plastic that looks like a servo harness that broke off underneath the dashboard on the driver side which has a piece of rod that controls the blenddoor. Can anyone tell me where I can get the plastic part? Do I have to buy the whole unit? Thanks you in advance on any inputs.
· Registered
Yeah, it looks like the air mix control lever cracked and fell down where it is in your picture. You have to buy the whole motor, unless you have the ability to scan and 3d print the lever. The part number is 79161-S6M-A41
Before you go getting a replacement, make sure the air control linkage moves smoothly. If it doesn't you'll need to try and repair the air mix door. If it can't be fixed, just get a replacement heater unit which will likely be used and include the air mix control motor.
· Registered
Thank you for your quick reply. How can I go by checking to see if it open smoothy? I can’t see which way I should pull. Right now, it’s blowing cold air. Last time I checked, I was trying to move around the rod and I can’t move it. I didn’t want to pull too hard that I might damage some other parts. The small area make it so hard to get into and see. Do you think the Door might be stuck?
· Registered
If pulling didn't seem to move it, did you try pushing it? If it doesn't move then that's probably why it is damaged like that. Getting the heater unit out will be a PITA, but it sounds like that may be your next step to better diagnose what's going on and how to fix it.
· Registered
I do agreed with you, it does looks like the harness is under a lot of stress in order to beaks off like that. I don’t get to mess with my car a lot. But I will see what happens to it in a few days. I really hope the door isn’t stuck. finger crossed. rather Or not the door is stuck, I still need to part you posted for me right?
· Registered
I recently had issues with my actuator not moving fully in either direction. The fix for my issue was to remove the two moving gear/pieces, cleaning them up and adding more grease to the meshing parts. I was dreading it being the blend door itself, but once I removed the 2 parts, I could spin the gear for the blend door effortlessly.
· Registered
Discussion Starter · #8 ·
wow, good to know. Thanks for the info. I’ll check to see if it is those parts that’s holding it from moving. is it easy to do? Looks like you only need a small screwdriver to remove one screw?🤣
· Registered
Yes, a stubby Phillips works the best. It's two screws for the two separate parts. You also will have to remove 1 or 2 10mm bolts holding the fuse box and try to move that out of the way in order to access the screws better.
· Registered
Oooh, envy! My '05 Type S has same issue, so did exactly the same as you, but to no avail. My blend door is extremely difficult to move. I've no idea what is jamming it up, but it absolutely will not move freely. Worked fine for years, then suddenly...
I'm in SoCal High Desert where summertime temps are typically triple digit, and winters get below freezing. Removing the bloody dash to get to the blend box is just not worth the trouble (at least to date) as I typically run the AC all summer and heat only in winter.
When it's time to switch, I slide under the driver's side dash and with key on, turn the temp control to either full heat or cold, then manually twist the blend door gear to "help it along"... It does not move easily, but does move. PIMA, lol... One day I'll sort it all out properly.
· Registered
Maybe the hing where the door attached to the heater unit needs a little cleaning and some fresh white lithium grease?
· Registered
Hmmm... You see the two white plastic bits in Baileysims's photo above...? The piece with the gear teeth meshes with a small gear mounted on the end of the blend door shaft. The best I could manage was to try to squirt some WD-40 behind the gear and onto the shaft - in hopes that perhaps the shaft was seizing up and preventing the blend door from moving easily - but unfortunately it did nothing to free it up. It's all I can do to twist the gear with my thumb and forefinger. No idea why it suddenly became reluctant to turn last year, it's always worked fine since new.
I did first remove the two pieces Baileysims removed, and likewise carefully cleaned, greased then reassembled (along with the WD-40 shot in the dark) but nope... When I turn the temp control knob to either full heating or cooling, the drive motor will move the assembly only a few degrees before the meshed gears begin slipping with an audible "pop, pop, popping" noise.
Only way I can get either full heating or cooling is by "helping it along" by hand, which means lying on my back with legs out the driver's door, and with key on, reaching up and twisting the temp control knob this way or that with one hand, while likewise twisting the blend door shaft gear with my other.
Since it's usually either really hot or really cold where I live, I do the manual "switch" beginning of the season and just live with it. Honestly only takes about 45 seconds, but still a PIA, lol. One day I'll sort it out... Thanks for the suggestion, btw, but this assembly is located immediately under the center dash and I see no way of opening up the blend box shy of removing the entire dashboard first in order to even get to it.
· Registered
Maybe try using a scope camera to get a closer look at things?
· Registered
That's an interesting idea, thanks. I've been wondering if possibly something might've dropped down into one of the dash vents and is interfering with the blend door movement. Would be nice if a scope could actually let me "see" down in there to get an idea of what's hanging things up.
· Registered
Discussion Starter · #15 ·
Hi guys, I still haven’t got the blend door look at. Hopefully in a few months I’ll get my act together and get it fixed. Now I came across another problem. I found water in the trunk by the spare tire area and they tire Jack area. it wasnt there when I purchased the car. I did some research and found out that this is a known issue by the tail light where the gaskets is leaking water. My question is, should I get eBay gasket, or should I buy oem? The way eBay is advertising seems pretty promising. Has anyone used eBay gasket? How are they holding up? Thanks in advance on any inputs.
1 - 15 of 15 Posts
