1 - 4 of 4 Posts
go big or go home . go big now or you will be mad at yourself later...i have compation clutch on mine stage 4 and it is sick...olso compation clutch 8lb flywheel..
drive mine every day and its just fine...it only takes a lit bit off the clutch to catch and thats ok. i have no prob wit it...
Simply put don't get a stage 4 like this guy said. With what you got on the car you will not need a heavy duty clutch like that. It will suck for daily driving and will be super stiff. A stage 1 or 2 will be perfect. Competition Clutches are what I always recommend to our customers. Their 1.5 clutch is pretty much the same as a stage 1 clutch. We offer a combo with either an 8 lbs flywheel or an 11.5 pound flywheel. This might be something you want to get as well since it would be easy to replace that as well when replacing your clutch. I linked you to a couple I feel would be good for your car.
http://www.kseriesparts.com/cr/CC-CK-8037-1.html
The exedy OE is much like your stock clutch it would be good for daily use as well.
http://www.kseriesparts.com/cr/EXE-KHC10.html
http://www.kseriesparts.com/cr/EXE-08806.html
drive mine every day and its ok .just fine...i dont understand what is the prob. it works great.
1 - 4 of 4 Posts
