1 - 8 of 8 Posts
Ive been lurking here for a while but still new to this platform as this is my first car.
Recently purchased a used 02 base model as a daily, Major problem i am having so far is when i put gas in the car and go to start up
the car will crank but not fully go on. i usually have to try to start it 2-3 times and when it does start the car sounds bad. but once i pull out everything seems to be ok..
i recently replaced the evap canister. could this be the issue or should i be looking for something else in particular ?
Thank you.
I assume you are filling up? If so, are you topping off the tank?
Do you have a restart problem only after a brief stop for fuel or does it happen after other brief stops?
ive only experienced this issue while filling up at the gas station
Light on or anything, and don't top it off--once it hits the stop don't add more, it sends fuel into the evap stuff. Or don't shut it off at a gas station.
Selling my RSX
Dadmobile ('14 Ford Edge SEL)
I second the purge solenoid valve. This happened with my wife's 07 Mazda 3. The code it threw was not clear and after puzzling the mechanics, replacing a MAF sensor for no reason, and not being able to pass inspection, I finally found some thread that said something about the lack of starting after a fill up and that the code could be a bad purge solenoid valve.
1 - 8 of 8 Posts
