1 - 6 of 6 Posts
· Registered
Ok hey man I'm not good at this forum so I just ask I have 02 base just put new trans in ok some ass hope kid stole my key and the ring that lights up or I guess the key position and steering lock ring.......found one kinda at the junk yard.......called the lick guy 257 he comes out and has a cut key works trurns the lights on everything.....no crank....I have the baterty in the back as well all wired correctly.......ok so the guy true to program the key it goes all the way and every step works key fob everything but the very end it says confirmed but third key failed plz rety....well the keys still flashing and I have a buz coming from the relay the first relay right there in the fuse box replaced it twice and still buzzes....now if I get down a mess with the transmisaion saftey switch and it will stop buzzing won't start but green key I need some help
· Vaginal Lubrication Tech
In short Honda diagnostic tool reads the key codes from the immobilizer unit around the ignition barrel and writes them to the ECU. The transponder codes in the keys must match the codes in the immobilizer and match the codes in the ECU for the car to start
· Registered
. Hey so yup your on the right path there now I haven't gone in deep to reading those instructions but they do kinda help me bypass the situation? I'll be here reading and then I'll be following the steps so answer of any kind would help more thanks
· Registered
The ring that goes around the key is called the immobilizer. The keys are coded to the immobilizer and the immobilizer is coded to the ECU. If you replaced the immobilizer than you need to take it to the dealer so they can reprogram the Keys, ECU and immobilizer.
While some scan tools like the Launch and Autel can add/delete keys, replace immobilizer and replace the ECU they all require the security light to be out in order to enter programming mode.
If the security light is flashing and you don't have any working keys, than you need to go to the dealer or a locksmith that has access to honda's service express/Security Professionals access.
See: https://techinfo.honda.com/rjanisis/logon.aspx and look at the Security Professionals section.
1 - 6 of 6 Posts
