1 - 10 of 10 Posts
i have been searching around and i couldn't find the answer, my question is do i need the X CLIPS for the HID light bulds to fit in the projector light? and i am using a regular H3 light bulds for the projector right now. im thinking to get a HID conversion kit cuz i have to change the light build every 1 or 2weeks.
Headlight Guy
No xclips needed for those, but you do want to use just any H3 HID kit in those projectors as it will result in a too narrow beam pattern. We offer special bulbs for those specifically
i installed the HID kit on those projector light, they all work fine, but it seem the left side projector is brighter than the right side. anyone know why?
No More Broken OEM Fogs
It could be many things ranging from the quality of the projector or lens to the bulb placement in the projector reflector bowl......that is where I would start first. Make sure the bulb is seated correctly.
The lenses in those things can be scetchy.....I've even gotten new ones that have had dust or some crap all over the insides of the lenses.....
www.retro-solutions.com sells a kit specifically for that type of application. From what I know it is the best possible solution for a plug and play kit for the halo projectors that take the h3 bulb.
D
here is the pic, the left side brighter than right side. and i know that the left side is higher than the right side, ill adjust that later.
looks like the bulb is not seated correctly...... that would be where I would start judging from the picture
1 - 10 of 10 Posts
