1 - 6 of 6 Posts
2003 Acura Rsx type s
  • What's up everyone so I just bought a "07" k24a to go in my rsx. Didn't really want jdm but that's what I ended up with. Now the motor has 3 lobe camshafts, says RAA on block, RBB on head and rbb on the bottom side of intake mani. Any help confirming identity would greatly be appreciated. And a few other questions for anyone that's done a jdm k24a swap. What sensors need to be replaced? They claimed it has usdm sensors already..? And I have a k20a2 with no compression in one cylinder I'm just wondering what all I should take off that for the k24a besides oil pump thanks for any help in advance. And if thats a stock clutch on there? And wasn't really sure where to post this but if I'm in the wrong spot by all means please move me thx
That’s better engine. That’s 200hp engine.
Do you know how I can tell forsure? Couldn't they have just put 3 lobe camshafts and rockers in it? And id like to difinitivly know what motor it is so I can try to get a manual on it and any info I can like are the Pistons domed or flat and if my 03 k20a2 intake manifold and throttle body will work with this motor. But I can research that stuff hopefully. Thx though I thought so because of the cams but I wasn't sure
This engine is k24a2 from 04-08 TSX. Real vtec killer because of the 3 cam lobes on intake and exhaust. Im swapping my base 5 speed with this engine.
Discussion Starter #6 (Edited)
Totally agree with you, it is a great angine with huge potential.
I have the motor in just waiting on the upper coolant housing. It should be here tomorrow. Any clue what Kal I should use? I'm not sure if I should look for a jdm Kal or just run the k24a2 kal.
1 - 6 of 6 Posts
