1 - 2 of 2 Posts
Hello i have a 2002 rsx ,i was changing my battery and had the obd2 hooked up to a memory saver on a small 12v battery. while i was changing my battery i tightened down the negative terminal then as i was tightening the positive terminal my socket wrench slipped and touch some body metal and produced a spark .the car is still running fine with no check engine lights, I've checked all the fuses in my two fuse boxes they are all fine. But my obd2 port will not connect to my bludriver and the radio will not power on as well even the fuse in the back of my radio unit isn't blown. Im just wondering if there is a way for me to test continuity to the obd2 port and radio and if its worth finding someone else to change any harnesses for me or if it seems like a simple job thank. you
1 - 2 of 2 Posts
