1 - 2 of 2 Posts
I have a clifford 330.3x
I got it installed years ago in a place that is closed now.
When armed I can still start the car, the alarm goes off but not starter kill.(everything else works)
I know the 3 starter kill cables are
GREEN/WHITE = starter common (key side)
GREEN = starter normally open(motor side)
GREEN/BLACK =starter normally closed(motor side)
The 3 starter kill cables in my car are wired this way
(the starter BLACK/WHITE cable was cut)
GREEN/WHITE connected to WHITE/BLACK key side
GREEN/BLACK connected to WHITE/BLACK starter side
GREEN no connection
I tried changing it from closed to open, but the car won't start like that.
Any suggestions??? help my alarm basically is just a siren :rest
Discussion Starter · #2 ·
Fixed
The problem was the yellow cable that tells the alarm brain when the car is on.
It was wired into the accessory! terrible installation! I wired it to the correct wire which is the ignition one (black/yellow).
Now if the alarm goes off car won't start:hb:
1 - 2 of 2 Posts
