1 - 5 of 5 Posts
Pach the cah
Hi Guys,
I searched around some and looked through the Service Manual, but was unable to find anything to answer my question.
The OEM spark plug cover has two bolts in the middle that cannot be removed (as far as I can tell):
I didn't have the ideal tools to really try to separate the bolt (if possible) so I thought I would ask b4 I strip something. Do I reuse the bolts above or do I need new ones:
Thanks!
www.magtuning.com
You can remove the bolts, don't be a baby with them, they are probably just really well stuck on there since you probably never touched them before
Spray some WD-40 or somethin on the bolts, and use a hammer, flip the cover over, and tape the bolts while trying to screw them out
no time to drive the RSX
Those nuts are removeable from the screw. Try putting a 10mm wrench on the screw while holding the nut & twisting it off.
1 - 5 of 5 Posts
